CADSMCMD Command Line Interface › cadsmcmd Commands › targetcomputer—Target Computer Commands › TargetComputer Commands Related to OS Installation Management (OSIM) › reactivateOS—Reactivate Stopped / Failed OS Installation Order › Example
Example
Assume that a stopped or failed OS installation should be scheduled for target computer dorabella. A wakeup This optional parameter specifies whether a target system in power standby mode shall be waked up for this installation or not. If wakeup or wakeup=y is coded, then the systems will be waked up. If wakeup=n is specified, no wake up will be performed. If the parameter is not coded, the default wakeup=n will be used. should be performed, if the target system were in power standby mode.
Furthermore, an automatic restart should take place to start the installation process at the target system. The following command provides this request:
cadsmcmd targetcomputer action=reactivateOS name=dorabella wakeup restart
