To retrieve information about the files of the fetched item "fetch 2 base" of the area "WWWWW01B", enter the following command:
cadsmcmd area action=listFetchedItemFiles name=WWWWW01B item="fetch 2 base"
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "<default manager>" as user "<default user>" ... ok. ------------------------------------------------------------------------------- File list of fetched item "fetch 2 base" of area "WWWWW01B" ------------------------------------------------------------------------------- File name..............................: actions.sxp ..File size............................: 260 ..File type............................: file ..Last modified at.....................: 2005-03-27 16:00 ..File attibutes.......................: A File name..............................: check.sxp ..File size............................: 166 ..File type............................: file ..Last modified at.....................: 2005-03-27 16:00 ..File attributes......................: A File name..............................: info.sxp ..File size............................: 431 ..File type............................: file ..Last modified at.....................: 2005-03-27 16:00 ..File attributes......................: A Number of items listed.................: 3 Number of items read...................: 3 SDCMD<A000000>: OK
To retrieve information about the file "info.sxp" of the fetched item "fetch 2 base" of the area "WWWWW01B" using filter, enter the following command:
cadsmcmd area action=listFetchedItemFiles name=WWWWW01B item="fetch 2 base" filter="File name=info.sxp"
The output is as follows:
File name..............................: info.sxp ..File size............................: 431 ..File type............................: file ..Last modified at.....................: 2005-03-27 16:00 ..File attributes......................: A Number of items listed.................: 1 Number of items read...................: 3 SDCMD<A000000>: OK
