CADSMCMD Command Line Interface › cadsmcmd Commands › area—Domain Management
Actions at the enterprise:
{list This action lists all Client Automation domains. To confine the amount of information a filter can be specified. | showattr This action lists the attributes of a Client Automation domain. | listmembership This action lists those Client Automation domain groups containing the specified Client Automation domain. | modify This action modifies attributes of a Client Automation domain. |
...listdistsw This action lists all software products distributed to a Client Automation domain. To limit the amount of information you can specify a filter. | removedistsw This action removes distributed software from the list of distributed software of a Client Automation domain. | listfetcheditems This action lists all fetched items of a Client Automation domain. To limit the amount of information you can specify a filter. |
...listfetcheditemfiles This action lists the fetched files of a fetched item of the specified Client Automation domain. To limit the amount of information, you can specify a filter. | removefetcheditem This action removes a fetched item from the Client Automation domain's list of fetched items. |
...addtodomains This action adds a Client Automation domain to a list of Client Automation domain groups. | removefromdomains This action removes a Client Automation domain from one or more Client Automation domain groups.} :
Note: The terminology of CA Client Automation has changed in comparison with Unicenter Software Delivery 4.0. The SD "area" is equivalent to the Client Automation "domain", while the SD "domain" is equivalent to a Client Automation group of domains.
Nevertheless for compatibility reasons the terminology, command, and parameter names of the CLI have not changed!
To avoid any ambiguity, in the subsequent sections an area (a domain in the terminology of CA Client Automation) is mentioned as a "Client Automation domain", and a domain (a domain group in the terminology of CA Client Automation) is mentioned as "Client Automation domain group".
The Client Automation domains are handled by the area command of the CLI and the Client Automation domain groups by the domain command of the CLI.
Note: The subsequent methods are valid on enterprise manager only.
This section contains the following topics:
General Actions
Distributed Software Management
Fetched Items Management
Containment Management
