This action removes procedures from a procedure group.
swLibrary action=removeProcFromPG name=procedure_group_name
procedure=procedure_name item=item_name version=item_version
Specifies the name of the item where the procedure is located.
Specifies the name of the procedure group from which the procedure will be removed.
Specifies the name of a procedure to be removed.
Specifies the version of the item where the procedure is located.
Note: This function only unlinks the procedure from the procedure group. It does not remove the procedure from the item nor does it affect any other procedure and software groups as long as they do not include the procedure group in question.
