To list the contents of the procedure group pg_1 the following command can be entered:
cadsmcmd swlibrary action=listPG name=pg_1
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- List members of procedure group "pg_1" ------------------------------------------------------------------------------- inst (tstbase 1.0 <1>) inst (tstkpk03 1.0 <2>) SDCMD<A000000>: OK
The tstbase entry should be replaced by two other entries invoking the procedures remdir and setdir. The following commands will modify the contents as required:
cadsmcmd swlibrary action=removeProcFromPG name=pg_1 procedure=inst item=tstbase version=1.0
cadsmcmd swlibrary action=addProcToPG name=pg_1 procedure=remdir item=tstbase version=1.0
cadsmcmd swlibrary action=addProcToPG name=pg_1 procedure=setdir item=tstbase version=1.0
The group pg_1 now shows the following contents:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "kkkkk01b" as user "<default user>" ...OK. ------------------------------------------------------------------------------- List members of procedure group "pg_1" ------------------------------------------------------------------------------- inst (tstkpk03 1.0 <1>) remdir (tstbase 1.0 <2>) setdir (tstbase 1.0 <3>) SDCMD<A000000>: OK
The procedures of a procedure group are executed at the target systems in the sequence they were ordered in the procedure group. This order number of a procedure is shown in pointed brackets. To execute the inst procedure in a correc manner the remdir and setdir must run first. The following command reorders the procedure group:
cadsmcmd swlibrary action=repositionItem name=pg_1 procedure=inst item=tstkpk03 version=1.0 position=3
Now the group pg_1 shows the following contents:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "kkkkk01b" as user "<default user>" ...OK. ------------------------------------------------------------------------------- List members of procedure group "pg_1" ------------------------------------------------------------------------------- remdir (tstbase 1.0 <1>) setdir (tstbase 1.0 <2>) inst (tstkpk03 1.0 <3>) SDCMD<A000000>: OK
