This action allows you to delete a software or procedure group.
swLibrary action=deleteGroup name=groupname [recursive]
Specifies the name of the group to be deleted.
Group names not valid for this method are "All Software" and "Catalog".
Not only the group will be deleted, but also all recursively contained subgroups.
Products or procedures assigned to a group to be deleted will be unlinked from that group but not deleted.
Note: If the group to be deleted does not exist, the action will be carried out with success (return code: SDCMD<A000000>: OK).
