Suppose a software group named "swg_1" should be created and after this, a procedure group named "pg_1," which is a subgroup of the already existing software group "swg_1". The following commands create these groups.
cadsmcmd swlibrary action=createGroup name=swg_1
cadsmcmd swlibrary action=createGroup name=pg_1 groupType=PG superGroup=swg_1
To check the creation the following command will list all the software and procedure groups available:
cadsmcmd swlibrary action=listGroups recursive
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Trace mode: Off Connecting to manager "<default manager>" as user "<default user>" ... ok. Manager: mymanager Domain: mydomain Domain type: Domain Supporting: CO CCNF USD OSIM ------------------------------------------------------------------------------- List of groups in the software library ------------------------------------------------------------------------------- Software Groups ..Group name...........................: Catalog ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-04-09 11:26 ....Change date........................: 2005-04-09 11:26 ..Group name...........................: Software Delivery ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-04-09 11:26 ....Change date........................: 2005-04-09 11:27 ..Group name...........................: swg_1 ....Comment............................: ....Creation date......................: 2005-04-10 08:51 ....Change date........................: 2003-04-10 09:11 ....Procedure Groups ......Group name.......................: pg_1 ........Comment........................: ........Creation date..................: 2005-04-10 09:11 ........Change date....................: 2005-04-10 09:11 SDCMD<A000000>: OK
Adding the argument "recursive" is important, otherwise the procedure group "pg_1" as a subgroup will not be listed, but only the top level groups.
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "kkkkk01b" as user "<default user>" ...OK. ------------------------------------------------------------------------------- List of groups in the software library ------------------------------------------------------------------------------- Software Groups ..Group name...........................: Catalog ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-04-09 11:26 ....Change date........................: 2005-04-09 11:26 ..Group name...........................: Software Delivery ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-4-09 11:26 ....Change date........................: 200504-09 11:27 ..Group name...........................: swg_1 ....Comment............................: ....Creation date......................: 2005-04-10 08:51 ....Change date........................: 2005-04-10 09:11 SDCMD<A000000>: OK
Now assume that a software group "swg_2" should also be created and a software group "swg_2_1" that is a subgroup of swg_2. Furthermore, another procedure group named pg_2 is needed. The following commands will generate these groups and the intended hierarchy:
cadsmcmd swlibrary action=createGroup name=swg_2 groupType=SWG
cadsmcmd swlibrary action=createGroup name=swg_2_1 superGroup=swg_2
cadsmcmd swlibrary action=createGroup name=pg_2 groupType=PG
Now the recursive list of groups shows the following:
CA IT Client Manager r12 ITCM Command Line Version 12.8.0.xxxx Copyright (c) 2014 CA. All rights reserved. Connecting to manager "kkkkk01b" as user "<default user>" ...OK. ------------------------------------------------------------------------------- List of groups in the software library ------------------------------------------------------------------------------- Software Groups ..Group name...........................: Catalog ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-04-09 11:26 ....Change date........................: 2005-04-09 11:26 ..Group name...........................: Software Delivery ....Comment............................: CA-Software Delivery Reserved Group ....Creation date......................: 2005-04-09 11:26 ....Change date........................: 2005-04-09 11:27 ..Group name...........................: swg_1 ....Comment............................: ....Creation date......................: 2005-04-10 08:51 ....Change date........................: 2005-04-10 09:11 ....Procedure Groups ......Group name.......................: pg_1 ........Comment........................: ........Creation date..................: 2005-04-10 09:11 ........Change date....................: 2005-04-10 09:11 ..Group name...........................: swg_2 ....Comment............................: ....Creation date......................: 2005-04-10 09:28 ....Change date........................: 200504-10 09:28 ....Software Groups ......Group name.......................: swg_2_1 ........Comment........................: ........Creation date..................: 2005-04-10 09:28 ........Change date....................: 2005-04-10 09:28 Procedure Groups ..Group name...........................: pg_2 ....Comment............................: ....Creation date......................: 2005-04-10 09:29 ....Change date........................: 2005-04-10 09:29 SDCMD<A000000>: OK
