This action lists all fetched items of a Client Automation domain. To limit the amount of information you can specify a filter.
area action=listFetchedItems name=area_name
[{filter=filter|filterfile=file_name}]
Specifies the name of a Client Automation domain. Its fetched items will be listed.
Specifies the expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute |
Type |
Item name |
String |
State |
[not yet ] copied |
Fetched at |
String |
Fetch path |
String |
Comment |
String |
filterfile
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
