This action lists all failed jobs related with this target computer. To confine the amount of data, a filter can be specified.
targetcomputer action=listFailedJobs
name=computer_name
[{alt |
{filter=filter|filterfile=file_name}
[detailed]}]
An alternative output list is provided.
An alternate list is provided based on the item name and version only.
In case of coding this parameter the value of the item and version parameter might contain database supported wild cards, for example,
for an arbitrary, even empty sequence of characters
for an arbitrary single character
For Microsoft SQL Server also the square brackets ("[","]") have a special meaning. This has to be taken into account when coding the name.
Information is listed in detail
Specifies the expression to confine the amount of information listed
For attributes valid to build atomic filter expressions see action "listjobs".
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
Specifies the name of the computer of which the failed jobs will be listed.
