This action lists those jobs, which are related to the system identified in the name parameter. An additional filter can be specified to restrict the list to only those jobs that fulfill the filter criteria. If no filters are given the complete list of jobs is shown. The filter is limited to100 bytes.
targetcomputer action=listjobs
name = computer_name
[{alt |
[{filter=filter|filterfile=file_name}]]
An alternative output list is provided.
An alternate list is provided based on the item name and version only.
In case of coding this parameter the value of the item and version parameter might contain database supported wild cards, for example,
for an arbitrary, even empty sequence of characters
for an arbitrary single character
For Microsoft SQL Server also the square brackets ("[","]") have a special meaning. This has to be taken into account when coding the name.
Specifies the expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute |
Type |
Job name |
String |
Job state |
{UNDEFINED | WAITING | DELIVERY_ORDERED | DELIVERING | DELIVERY_OK | DELIVERY_ERROR | ALREADY_DELIVERED | EXECUTION_ORDERED | EXECUTING | EXECUTION_OK | EXECUTION_ERROR | UNDELIVERY_ORDERED | UNDELIVERING | UNDELIVERY_OK | UNDELIVERY_ERROR | ALREADY_INSTALLED | MANIPULATION_NOT_ALLOWED} |
Item name |
String |
Item version |
String |
Item type |
{SOFTWARE | DOCUMENT | PROCEDURE | UNSEALED ITEM | ENABLED ITEM | DETECTED ITEM | ARCHIVED ITEM} |
Procedure name |
String |
Ordered by |
String |
Error message |
String |
Error cause |
Long |
Comment |
String |
Computer installation procedure |
String |
Creation date |
Sdate |
Creation time |
Stime |
Activation date |
Sdate |
Activation time |
Stime |
Completion date |
Sdate |
Completion time |
Stime |
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
Specifies the name of the computer of which the jobs will be shown.
