This action lists all software products distributed to a Client Automation domain. To limit the amount of information you can specify a filter.
area action=listDistSW name=area_name
[{filter=filter|filterfile=file_name}]
Specifies the name of a Client Automation domain. For it the distributed software will be listed.
Specifies an expression to confine the amount of information listed
The following attributes are valid to build atomic filter expressions:
Attribute |
Type |
Item name |
String |
Item version |
String |
Specifies the name of the file that contains the filter commands.
The commands in the file are specified in the same way as in the filter parameter, but the size of the file is limited by the capacity of the system that runs this command.
