Symptom:
I registered a virtual host and later on I registered a new guest system (such as HP-UX vPar). After registration of the guest system, I do not see the relationship between this guest system and its related virtual host. What went wrong?
Solution:
By default, the relationship between a virtual host and its guest system is created only when the virtual host is registered. If any guest system is registered afterwards, no relationship will be established.
You can manually start the asset management agent on the agent machine with the configured virtual host inventory collect task, or wait until the next scheduled asset management agent process.
