Symptom:
When I compare the installed version of amVMAgent with the version that is displayed in the DSM Explorer user interface, I find that the versions are not the same.
Solution:
If you use amVMAgent (of different version) to do the registration manually by placing the inventory file amvminvux.inv into the $CA_ITRM_BASEDIR/Agent/AM/data/transfer_vm folder, the version number of the virtual agent that is registered using this method will be the same as amVMAgent on that computer.
