The SCCM Server tab is used to provide information about the SCCM Site server that will be the target for the extraction.
Use this procedure to configure the SCCM server option.
To configure the SCCM Server option
Each SCCM Site installation has a three-letter site ID. It is possible to install several SCCM sites on the same server as long as they have different site IDs, and, in such cases, this field must be used to specify which site the Asset Converter task connects to.
When only one SCCM site is present on the server, this field should be left empty, as the Asset Converter automatically chooses the only available site ID.
The user specified must be able to access (remotely) the SCCM WMI classes on the server machine.
A successful result here does not guarantee the same outcome from the task once it is performed by an engine, as it could then be running on a different machine and in a different user context. The test performed when you click on the Test Connection button in the Create New Task dialog is performed on the machine running the GUI and in the context of the user running the GUI. When the actual SCCM Converter task is run it is done on the engine machine and in the context of the user account used by the engine (the local system account by default). This means that a successful test does not guarantee a successful connection when the task is actually run. You can eliminate the potential differences by making sure you include the domain name in the Username field of the configuration (in this format: domainname\username). If this is not done it will default to the domain of the current user which for a default engine amounts to the local users of the engine machine. If possible the test should also be performed on a machine which has the exact same access to the SCCM installation as the engine machine meant to perform the conversion.
