Previous Topic: Accessing the System ControllerNext Topic: HP-UX
Test the Virtual Host Inventory Manually
You can test the virtual host inventory manually and verify that the correct information has been collected.
Note: Running the inventory collection module manually is for testing or diagnostic purposes. In some situations, diagnostic messages are displayed on the screen, which does not affect the inventory collection and is not harmful.
To test the virtual host inventory manually
  1. Create a virtual host inventory collect task using the DSM Explorer.
  2. Enter the following command in the Solaris domain where the asset management agent is installed:
    caf start amagent
    Note: Starting the amagent will automatically start the AM remote agent and the registration process.
    The system controller inventory is written to the following location:
    $CA_ITRM_BASEDIR/Agent/AM/data/transfer_vm/12amvminvux.inv
  3. Check the information in the inventory file against the output from various commands specific to the system controller.
    Note: For more information, see the Sun Fire Midrange System Controller Command Reference Manual (http://docs.sun.com/source/) and the Sun SPARC Enterprise M3000/M4000/M5000/M8000/M9000 Servers Administration Guide (http://dlc.sun.com/pdf).
