The NRI Elective Inventory web site can be customized to adhere to your organization's standards.
The main page for the NRI solution is “ei.jsp”, which is located in the ...\DSM\Web Console\webapps\wac\jsp\ei folder.
Important! Do not change or overwrite any of the server side scripting tags in the file. Server-side code is encapsulated in a “<%” starting tag, and a “%>” ending tag.
Images currently used by the web page are located in the ...\DSM\Web Console\webapps\wac\jsp\ei\images folder. The CA logo file is called “circleca.png” and can be substituted with a logo matching your organization. Alternatively, a new logo file can be placed in this folder. You must change the reference in the “ei.jsp” file to point to the new logo.
Labels displayed on the page are externalized to the file named “i18n_ei.properties” located in the ...\DSM\Web Console\webapps\wac\WEB-INF\classes\com\ca\wac\ei\i18n folder.
For each change to take effect a restart of the Tomcat service is necessary. Run the following commands to restart the Tomcat service:
caf stop tomcat caf start tomcat
Note: Before making changes to the web site ensure to back up your files.
