Customizing Asset Management › Virtual Hosts › HP-UX › HP Integrity Virtual Machines › Installation › Prerequisites for Accessing the Integrity VM Host (BAR)
The SSH keys must be generated on both the VM Host and the VM Guest systems. You must perform the following prerequisites for accessing the VM Host:
- The HP-UX Distributed Systems Administration Utilities (DSAU) tools can be used to set up the SSH keys on the VM Host and the VM Guest systems, which is installed by default on HP-UX 11.23 (0512 release) or later.
- The “/opt/dsau/bin/csshsetup $VMHostName” command is used to set up the SSH keys between VM Host and the VM Guest systems. Once the SSH keys are set up, the agent uses SSH and accesses the VM Host to collect the relevant inventory information.
