The Advanced Scan package offers software detection through the Client Automation software signature scanner. The signature scanner uses a signature database to recognize the installed software. During installation of the Non Resident Inventory solution a version of the signature database file is also installed.
The Client Automation system automatically downloads new signatures to the core Client Automation system for use with the real Client Automation agent and beyond, custom created ones might be added as well. However, the Non Resident Inventory solution is not included in these automatic updates, so you have to perform these updates manually.
To manually update the signature database used by the Advanced Scan package
The folder contains a list of W0000xxx.zml files.
