The following table lists the command line switches that the NRI agent recognizes:
Command |
Description |
-o “<output path>” |
Specifies the location where the agent should put the inventory XML file. |
-origin “wished origin” |
Specifies the origin of the asset. See the Asset Collector documentation for more information on origin. |
-trustlevel <trustlevel> |
Specifies the trust level of the asset. The trust level can be a number between 1 and 5. See the Asset Collector documentation for more information on trust level. |
-file “[set the File Name variable]” |
The output file is by default named using the generated host UUID. This can be overridden through this parameter. |
-nohw |
Do not collect hardware inventory. |
-nosw |
Do not collect software inventory. |
-script <script file> |
Location of script file. |
