For each supported platform the script file contains a Download <Platform> section. This section describes for the Web Launcher what and how to download files for the specified platform. The following is an example for the Windows platform.
Example: Download <Platform> Section
[Download_Windows] Method=webservice Executable=cmNriAgent.exe CommandLine=-script .\adv.ini Files=2 File1=basic_heuristic.exe File2=w0000001.zml,w0000001.xml
The following table includes the parameters available in the Download <Platform> section:
Parameter |
Description |
Method |
Defines the method to use to download the files. Currently only "webservice" is supported. |
Executable |
Defines the name of the executable the primer should execute when all files are downloaded. |
CommandLine |
Specifies the command line to use when executing Executable. |
Files |
Indicates the number of files to download. |
FileX |
Specifies the name of the file to download. Specify uncompressed name after the comma. Note: For more information, see Compressing and Uncompressing Files for Download. |
