The Advanced section currently contains only the following item.
Example: Advanced Section
[Advanced] KeepWorkArea=0/1
The following table includes the parameters available in the Advanced section:
Parameter |
Description |
KeepWorkArea |
Default value is 0. If the value is set to 1, the NRI Primer does not remove all downloaded files. Generated inventory files are not deleted as well. |
