To store the origin and trust level information of the assets/users, the following schema changes have been made to asset tables:
Table Name |
Column Name |
Column Datatype |
Column Null Option |
Column Comment |
inv_root_map |
trustlevel |
integer |
not null |
Defines the trust level for a component discovered on an asset/user. Default: 5 |
inv_root_map |
origin |
nvarchar(64) |
not null |
Defines the origin information for a component discovered on an asset/user. |
ca_agent |
trustlevel |
integer |
not null |
Defines the trust level of an asset/user. Default: 5 |
ca_agent |
origin |
nvarchar(64) |
not null |
Defines the origin of an asset/user. |
ca_discovered_hardware |
external_host_key |
nvarchar(64)
not null |
Defines the key generated or passed by the Asset Collector. |
ca_discovered_software |
trustlevel |
integer |
Defines the trust level of discovered software of an asset/user. Default: 5 |
origin |
nvarchar(64) |
not null |
Defines the origin of discovered software of an asset/user. |
