Reconciliation is the process that is applied if an agent is installed onto an asset that was being reported through the Asset Collector. The Asset Collector information is overwritten with the information from the agent. Any subsequent inventory from the Asset Collector is ignored.
The Asset Collector cannot be used to append inventory information to a currently reported asset.
Note: For reconciliation to work the asset registered by the Asset Collector has to be using the same Media Access Control (MAC) address and host name as the computer.
Reconciliation also occurs for user objects that are created using the Asset Collector. The User is registered using a URI as its key. If a user with the same URI is registered via a DSM Agent, it overwrites the collected information, and any subsequent Asset Collector inventory for this URI is ignored.
