Polite scan lets you set process priorities for your software scan and the asset management agent. Polite scan minimizes the hard drive load during the file scan and thus reduces the I/O time consumed by the software scanner.
For Windows agents, polite scan is implemented for the best performance.
For Linux/UNIX Agents, polite scan can be configured either during installation or by modifying the comstore.xml file after installation, as described in the Configure Polite Scan after Installation section.
Note: Do not use an editor to modify the comstore.xml file.
