You must configure polite scan to specify the priorities for the signature scan and the asset management agent. You can do this either during installation or after installation. Based on the priority set, the agent can run at any priority level.
Note: Polite scan can be configured only on UNIX/Linux agents.
To configure polite scan after installation
caf stop
The caf process stops.
ccnfcmda -cmd SetParameterValue -ps /itrm/uam/prio_value -pn Client -v Value
The value can range between -20 and 19:
Indicates that the agent will run with high priority.
Indicates that the agent will run with low priority.
Indicates that the agent will run with default or normal priority.
caf start
The agent runs with the configured priority.
