The software usage server allocates the licenses based on the access level of the assets. You can assign appropriate access levels to the computers and users based on the priority that you set, for example, you can assign Power Unit access to those computers or users whose access to the application is very critical. You can assign different access levels to different applications.
To assign access levels to an asset
The Software Rights for asset dialog appears.
The application is added under the asset name with the given access level.
The access levels are assigned to the asset.
