The software usage collect task offers the software licensing administration feature which can be used to do the following:
Important! This configuration must be done very carefully as the user will not be able to run any other application than the specified ones. You must test your configuration in a test environment before applying it on a live environment.
You can select the applications you want to monitor, specify the number of available licenses per application, and indicate the action to be taken if the specified number is exceeded. You can specify the following actions:
You can monitor the whole site, a particular group of assets, or a single asset. You can set up the software usage collect task to distinguish between the software packages installed on local drives and on network drives.
Though you can configure software usage collect task both at the computer and user level, configuring it at the computer level lets the software usage agent run as a service using the Local System account. This ensures that the agent is running always, regardless of which user has logged in.
Note: The software usage feature is available for all the software signature definitions defined in the database. However, for virtual applications, software usage and auditing are not supported.
