Previous Topic: Disable a Collect TaskNext Topic: Configuring the Collect Task to Control Content Distribution
Delete a Collect Task
You can delete a collect task that you no longer use.
To delete a collect task
  1. Navigate to the Control Panel, Configuration, Collect Tasks folder.
    The various collect task types are displayed in the right pane.
  2. Double-click the collect task type of the task.
    All the collect tasks available under the type are displayed.
  3. Right-click the task that you want to delete and select Delete.
    The Confirm Delete message appears.
  4. Click Yes.
    The task is unlinked from all the linked assets and groups and deleted from the database.
