When you create a collect task, you enable scanning automatically. You can disable scanning on agents, groups, and user accounts by disabling the collect task.
To disable a collect task
The right pane displays the collect tasks that apply to the group or agent.
A context menu appears.
The collect task is disabled for the individual agent (if you selected an agent) or for all agents in the group (if you selected Group Details).
