Previous Topic: Run the Content UtilityNext Topic: Content Utility Log Files
Configure the Content Utility
When the Content Utility runs for the first time, it generates a configuration file named content_utility.xml in the Installation path\CA\DSM\bin folder. You must configure this file to set the following parameters:
The content_utility.xml looks like this after the first run:
<contentutility_configuration>
	<general>
		<datadirectory>default</datadirectory>
	</general>
	<export>
		<manager>
			<hostname>machine001.ca.com</hostname>
  			<enabled>yes</enabled>
  			<ca_provided>no</ca_provided>
 			<custom_created>yes</custom_created>
  			<ca_intellisig>no</ca_intellisig>
  			<custom_intellisig>yes</custom_intellisig>
  			<intellisig_detail>yes</intellisig_detail>
		</manager>
	</export>
	<import>
		<manager>
			<hostname>machine101.ca.com</hostname>
		</manager>
	</import>
</contentutility_configuration>
General Section
This section has the following tag:
datadirectory
Defines the location of the export and import files. The default path is C:\Documents and Settings\All Users\Application Data\CA\software_definitions.
Export Section
In this section, you can specify the following parameters for exporting the files:
hostname
Defines the name of the DSM manager where you want to export the files.
ca_provided
Defines whether the CA Provided definitions must be exported.
custom_created
Defines whether the custom software definitions must be exported.
enabled
Specifies whether files are to be exported.
ca_intellisig
Specifies whether the CA Intellisig must be exported.
custom_intellisig
Specifies whether the Custom Intellisig must be exported.
intellisig_detail
Specifies whether the Intellisig Details must be exported.
Import Section
In this section, you can specify the following parameters for importing the files:
hostname
Defines the name of the DSM manager where you want to import the files.
ca_provided
Defines whether the CA Provided definitions must be imported.
custom_created
Defines whether the custom software definitions must be imported.
enabled
Specifies whether files are to be imported.
ca_intellisig
Specifies whether the CA Intellisig must be imported.
custom_intellisig
Specifies whether the Custom Intellisig must be imported.
intellisig_detail
Specifies whether the Intellisig Detail must be imported.
