The Content Utility tool lets you share software definitions between independent Client Automation installations. The new and updated software definitions provided by CA Technologies are first downloaded to an online domain (or enterprise) manager that has access to the Internet, and then can be imported into all the offline domain (or enterprise) managers.
The exported definitions are saved as text files that can be shared by installations that are either not part of the same network or run in an offline environment.
You can export the software definitions to files on a shared network location or a portable media, such as a USB device, and then import them into the offline installations.
The utility works with both CA Technologies provided and custom-created software definitions and is available as a command line utility.
