Previous Topic: Synchronize Intellisig Definitions with a Remote DatabaseNext Topic: DMScript Extensions
Replicating Intellisigs
You can create your custom Intellisig definitions on the enterprise manager and can replicate these definitions. Replication helps ensure that you do not need to define the definitions separately on each domain manager.
(Optional) Modify Replication Settings for Intellisig Definitions
You can modify the default replication settings that are defined in the replication task.
  1. Open DSM Explorer. Navigate to Control Panel, Configuration, Configuration Policy, Policy name and right-click the policy and select Unseal.
  2. Navigate to Manager, Engines under the configuration policy.
  3. Specify values for the following configuration policy parameters:
    Ignore replicated Intellisig if they are locally defined
    Controls the behavior of the replication if the Intellisig definition was previously created locally at a domain manager. If you set this parameter to true, the master definition and details from the enterprise manager are not replicated. Otherwise, the master definition at the domain manager is updated by the definition from the enterprise manager. Its domain_uuid is changed to that of the source. The existing definition at the domain manager is updated. Any existing details of the master at the domain manager are deleted. The Intellisig details from the enterprise manager are replicated to the domain manager.
    Default: False
    Convert replicated Intellisigs on unlinking
    Overrides the default behavior that deletes all replicated master Intellisig definitions and their details at the domain manager on unlinking. If you set this parameter to true, on unlinking, any replicated master Intellisig definition and details are converted at the domain manager as belonging to the domain manager. Namely, their domain_uuid is changed from that of the enterprise manager to that of the domain manager.
    Default: False
    Leave replicated software definitions
    Specifies whether the replicated heuristic and Intellisig detected software definitions must be retained at the enterprise manager when the domain managers have removed them. If set to False, they are deleted at the enterprise manager when the last domain manager reports them as deleted.
    Default: False
    Leave unreferenced software definitions on collection
    Specifies if heuristic software definitions must be left undeleted at the domain manager, on an engine collect, when their last discovered software instance is deleted.
    Default: False
  4. Save and the seal the policy. Apply the policy on computers that host the DSM engine, which runs the replication tasks.
Back to Top
More information:
Considerations for Using Intellisigs in an Enterprise Manager Setup
An enterprise manager replicates detected software definitions and discovered software records when a domain manager is linked to the enterprise manager. After the replication process, you can view, query, report, and synchronize the information from a single location.
The following considerations apply when you use Intellisigs in an enterprise manager setup:
Back to Top
