Previous Topic: Reconciling Intellisig Data with other CA ProductsNext Topic: Replicating Intellisigs
Synchronize Intellisig Definitions with a Remote Database
Detected Intellisig software definitions and their discovered software instances are added to the synchronization configuration when the synchronization task is created, if the target MDB supports Intellisigs. If the synchronization task already exists, the configuration are updated when the task next runs.
This is applicable for both CA-provided and custom Intellisigs.
The master Intellisig definition of the detected software definitions are created during the first phase of synchronization when you run the content utility.
Detected software definitions are matched with any existing definitions at the target (originating from other MDB sources).
Links of detected software definitions to manufacturers and categories are replicated to the target MDB with the manufacturers and categories created if required. Any previous category membership created by Intellisig are deleted. But any category membership created manually are preserved.
On deleting the synchronization job and selecting cleanup, the discovered software that originated from the source MDB are deleted. If this is the last source MDB, the detected software definitions and master Intellisigs without details are also deleted.
