Previous Topic: intellisigcmd - Command Line ToolNext Topic: intellisigcmd import—Import Intellisigs
intellisigcmd export—Export Intellisigs
The intellisigcmd export command lets you export Intellisigs. You can either use the DSM Explorer or the command to export Intellisigs.
Command format:
intellisigcmd export file=<export name> [type=xml|zip] [platform=all|windows|unix]
export name
Specifies the name of the Intellisig XML or zip file that you want to export. If you do not provide the file extension, and the type is xml, the command creates a folder with the given name.
type
Specifies whether you want to export an XML or zip file. If you do not include the type parameter, the command assumes the export type depending on the export file extension.
Valid values: xml, zip
platform
Specifies the platform for determining which Intellisigs are exported.
Valid values: all, windows, unix
Default: all
