Previous Topic: Set Default Timeout for IntellisigsNext Topic: intellisigcmd export—Export Intellisigs
intellisigcmd - Command Line Tool
intellisigcmd is a command line tool for Intellisigs. This tool has the following format:
intellisigcmd <cmd> param1=value1 param2=value2 ... [<DB_Credentials>]
cmd
Specifies the import, export, or genuuid command.
DB_credentials
Specifies the database credentials of the MDB. By default, the credentials are retrieved from the comstore.
Use the following sample format to specify the DB credentials:
Example: SQLServer DB Credentials
dbvendor=mssql dbhost=myhost dbname=mdb dbuser=ca_itrm dbpassword=mypwd dbinstance=inst
Example: Oracle DB Credentials
dbvendor=oracle dbhost=myhost dbname=orcl dbuser=ca_itrm dbpassword=mypwd dbinstance=1521
