The Reporter generates the SQL script for the purpose of exporting it, and the option is only available if all fields and options of the report template support it. The fields that require local processing cannot be expressed in SQL, and templates containing such fields cannot be exported as SQL scripts.
You can export the SQL scripts to the clipboard or to a file. Right-click the report and select Export, Export SQL script to clipboard or Export SQL script to a file respectively.
