Previous Topic: Understand the Types of SignaturesNext Topic: Create a Suite
Create a Product
Products are the basis for a definition. You must create a product before you can add releases or suites to it.
To create a new product
  1. Navigate to the Domain, Software, Definitions, Categories folder in the DSM Explorer.
    The existing categories in the domain appear.
  2. Select an existing category or create a new one by clicking New Category in the Tasks section.
    The existing definitions in the category appear.
  3. Right-click the category and select New Product.
    The Create New Product dialog appears.
  4. Enter the product name and version, and click OK.
    A message appears asking whether you want to create a release for the product.
    1. Click Yes.
      The Create New Release dialog appears where you can specify the details of a new release.
    2. Click No.
      The product is added to the category.
      Note: The product by itself does not have any meaning. You must create either a release or patch to give the specifications for the signature.
More information:
Create a Suite, Release, or Patch
You can create a Suite, Release, and, Patch by specifying the software recognition parameters manually from the user interface or by importing the XML file.
Specify Software Recognition Parameters from the User Interface
You can create a Release, Patch, or a Suite from the user interface as shown in the following steps:
