Previous Topic: How to Create a Custom Software SignatureNext Topic: Create a Product
Understand the Types of Signatures
A software signature defines the attributes of a software application, such as the main executable file name, other associated files, size range, version range, creation, and modification dates of the software. All these attributes of a software signature uniquely identify a software application. Software signatures in asset management are created as software definitions. You can create software definitions for a product, release, patch, suite, suite component, or virtual application image. By default, asset management provides predefined software signatures covering the most widely used software in the IT industry.
Note: You cannot modify the predefined or CA Provided signatures.
You can also create new software signatures for discovering the licensed software you use or you can add new releases or patches to the existing product definitions. Creating the software definitions at the domain level displays the discovered software information at the domain level only. However, when you create it at the enterprise level, the discovered software information is shown and is usable at both the levels—domain level and enterprise level.
You can create a Suite, Release, and, Patch by specifying the software recognition parameters manually from the user interface or by importing the XML file.
You can create the following type of definitions:
Product
Defines the basis for a software definition. This container component comprises releases and suites. A product must have the following components. For example, Microsoft Outlook 2000 is a product. A product definition has only the version information.
Release
Includes a specific release of software. Release definitions can be created only for the products. For example, Microsoft Outlook 2000 SP2 is a release.
Patch
Includes the fixes for a release. Patches can be created only for releases. For example, Q303833 is a patch for Microsoft Outlook 2000 SP2 release.
Suite
Includes a software suite that comprises various individual and integrated products. For example, Microsoft Office. A suite definition can be created only for the products.
Suite Component
Includes the individual product in the suite such as Microsoft Word. This definition can be created only for the suites.
Virtual Application Images
Defines the basis for a virtual application image software definition. Note that CA cannot provide software definitions for recognizing virtual application images in the Content Download service, the DSM administrator must create these virtual application image definitions.
When the agent scans the computer for the software signature specifications, verifies that all the specifications are met; the software is recognized.
More information:
Create a Product
Create a Release
Create a Patch
Create a Suite
Signature Scanning for Virtual Applications
