In the case of offline utilization, the start and stop of the monitored applications are logged locally on the agent's working directory on the computer asset. When the asset management agent runs next time, the engine updates this information in the database. You can view the list of applications from the Offline Utilization View window.
You can also create reports based on the offline utilization data.
Note: If the offline utilization data is not displayed in the DSM Explorer, stop the running application and then start the asset management agent.
