Auditing registers any application that has been started and stopped on the computer without specifying the applications to monitor. The Software Usage feature includes the function of auditing executable files, DLL files, and Windows Services.
Note: UNIX Agents support auditing on executables only.
The Audit functionality is designed to run with the software usage agent. You must add one application, and then enable Auditing in the software usage collect task.
Note: Enabling Audit for all computers will generate a huge amount of network and database traffic. It must be used mainly by single assets or asset groups, for detecting new or illegal applications.
