Configuring Asset Management › Collect Tasks › Template Inventory › Create, Configure, and Schedule Template Inventory
You can create and configure a template inventory collect task to collect the inventory information configured in the selected template detection modules.
To create and configure a template inventory collect task
- Navigate to the Collect Tasks folder at the asset or group level and click New.
The Select New Collect Task Type dialog appears.
- Select the collect task type and click OK.
The Schedule New Collect Task dialog appears.
- Enter a unique name for the collect task and click Set Scheduling.
The Scheduling Options dialog appears.
- Specify the scheduling options and click OK.
The Scheduling Options dialog closes and the Schedule new Collect Task dialog appears.
- Select the Template Modules tab, select the template modules you want to collect the inventory from and click OK.
The template inventory collect task is saved with the above settings.
More information:
Check the Status of a Collect Task
Inventory Template Modules
