The Discovered Software report displays additional details such as the installation path and the number of installations. You can export this report to a csv file and save it in your hard disk.
To view and export the discovered software information
The discovered software are displayed in the right pane. This information is available only if the software inventory collect task runs successfully.
The context menu appears.
The Software Report for Computer dialog appears.
The report is exported to a csv file.
