The default Software Inventory Configuration collect task is configured to perform the signature scanning. If you want to collect heuristic scanning results or the unknown software information for a particular group or asset, you can create a new collect task, configure it, and schedule the task on the assets or groups.
To create, configure, and schedule a software discovery collect task
The Select New Collect Task Type dialog appears.
The Schedule New Collect Task dialog appears.
The Scheduling Options dialog appears.
The Scheduling Options dialog closes and the Schedule new Collect Task dialog appears.
Enables heuristic scanning. Click Configure Scanner to include or exclude the sources to be scanned. Valid options are:
Enables signature scanning. Click Configure Scanner to include or exclude the sources to be scanned. Valid options are:
The asset management agent performs different actions to collect the information under these two methods.
