If you have existing installations of Open Workbench and CA Clarity PPM Schedule Connect, you must uninstall the programs before installing newer versions.
You must install <CAPPM Schedule Connect to enable communication between CA Clarity PPM and Open Workbench. If you already have Open Workbench installed, you need only to install CA Clarity PPM Schedule Connect.
You can download Open Workbench and CA Clarity PPM Schedule Connect from the CA Clarity PPM DVD or from CA Clarity PPM. To download from the DVD, navigate to Clients\OpenWorkbench and click owbsetup.exe. To download from CA Clarity PPM, select the Open Workbench Download link from the Account Setting: Software Downloads page. The executable file name downloaded from CA Clarity PPM is wbsetup.exe. Run the executable to install the software.
Note: See the CA Clarity PPM Common Features and Personal Options User Guide for more information on how to download software from CA Clarity PPM, including installing Open Workbench and CA Clarity PPM Schedule Connect.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
