Uninstall Open Workbench and CA Clarity PPM Schedule Connect
Best Practices: If you are using Open Workbench with CA Clarity PPM, before you upgrade to a newer version of Open Workbench and CA Clarity PPM Schedule Connect, first uninstall the programs.
To uninstall Open Workbench and CA Clarity PPM Schedule Connect
  1. Select Start, Settings, Control Panel, Add or Remove Programs.
    The Windows Add or Remove Programs dialog box opens.
  2. Remove the following programs:
  3. Delete the CA Clarity PPM Schedule Connect folder.
    Note: If you accepted the defaults during the installation, this folder is located in CA\Clarity folder of your Program Files directory.
More information:
How to Set Up Open Workbench with CA Clarity PPM
Install Open Workbench and CA Clarity PPM Schedule Connect
