You must install CA Clarity PPM Microsoft Project Interface with CA Clarity PPM Schedule Connect to take advantage of all features. If CA Clarity PPM Schedule Connect is already installed with Open Workbench, you must also install CA Clarity PPM Microsoft Project Interface with CA Clarity PPM Schedule Connect.
To install CA Clarity PPM Microsoft Project Interface with CA Clarity PPM Schedule Connect
On the DVD navigate to Clients\MSPInterface and click mspsetup.exe, or if you have rights to download software from CA Clarity PPM, you can download CA Clarity PPM Microsoft Project Interface (which includes CA Clarity PPM Schedule Connect) from CA Clarity PPM.
Note: See the Common Features and Personal Options User Guide for more information.
A dialog box appears asking your language preference for the installer.
A series of dialog boxes take you through the setup process.
Note: If you have an existing installation, a message appears asking if you want to copy files to the same directory. Click Yes to continue.
The setup may take a few moments. A dialog box appears when the files are copied to their destinations.
Important! You must launch CA Clarity PPM Microsoft Project Interface with CA Clarity PPM Schedule Connect to enable communication between CA Clarity PPM and Microsoft Project.
Note: If you have an existing installation, a message appears asking you to confirm the upgrade. Click Ok to continue.
A series of installation dialog boxes take you through the process.
Note: A dialog box for Program Maintenance may appear if CA Clarity PPM Schedule Connect is installed with Open Workbench. Click Repair to continue.
The Install Completed dialog box appears last when the installation completes successfully.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
