The MSPAdd2k.MPP file is the CA Clarity PPM Microsoft Project Interface macro that adds CA Clarity PPM Integration as a toolbar or menu in Microsoft Project. Before enabling the macro, check for the following:
Once you enable the macro and you restart Microsoft Project, CA Clarity PPM Integration appears as a toolbar or menu, depending on your setup selection.
To enable the CA Clarity PPM Microsoft Project Interface macro
C:\Program Files\CA\Clarity\CA Clarity PPM MSPInterface\data
Note: Do not open this file from Microsoft Project using File > Open.
A dialog box appears asking if you want to enable macros.
Microsoft Project launches and a dialog box appears asking if you want to display CA Clarity PPM Integration as a toolbar or menu.
The macro is enabled and the CA Clarity PPM Microsoft Project Interface setup is complete.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
