Deploy and Configure the Service Cartridge › Deploy the Content Pack › Update Service Offering Configuration
The following configuration changes enforce and support the design of the virtual desktop automation content. Set all the following properties to the values as indicated:
- Click Service Builder, Configuration, Request Management Configuration.
The Property section appears.
- Click Modify against Allow Only One Service per Request property. Click Allow Only One Service per Request check box and click Update Configuration.
- Click Modify against Browse Catalog: Show Folder Icon, Click Browse Catalog: Show Folder Icon check box and click Update Configuration.
- Click Modify against Allow Discrete Handling of Service Options After, select the value to Submitted and click Update Configuration.
An error message appears.
- Ignore the error message, click OK to continue.
- Click Modify for property Access Control: Show Amount Column, click Catalog User from the Available list and click the single right arrow.
Catalog User appears in the Selected list.
- Click Update Configuration.
The service offering configuration is updated. You can log off from the service portal.
