Previous Topic: Reserve and Manage Virtual Machines with Hyper-VNext Topic: User and Access Management
Manage the Lifecycle of VMware ESX Virtual Machines
As a Service Consumer, your responsibilities require you to work with virtual machines. The self-service portal allows you to reserve VMware ESX virtual machines and manage their lifecycles. Use the self-service portal to perform the following tasks:
Reservations and management requests are subject to approval by your Service Provider or administrator. You receive emails with information about how to access your virtual machines and the status of your requests.
The following diagram illustrates how to reserve and manage VMware ESX Virtual Machines.
Reserve and Manage VMware ESX Virtual Machines
Perform the following tasks to reserve and manage a virtual machine:
  1. Access VMware ESX Management
  2. Select Reservation Type
  3. Manage Your Reserved Machines
The self-service portal lets you reserve and manage virtual machines. The portal centralizes, expedites, and automates virtual-machine requests. The portal is accessible from CA Service Catalog with the URL and credentials that your Service Provider provides.
  1. Log in to CA Service Catalog.
  2. Click Requests.
    The available services list opens.
  3. Click Server Automation Services, VMware ESX Management.
    The VMware ESX Management page opens. You can use the page to request VMware ESX machines and manage their lifecycles.
You can reserve a virtual machine (or machines) in the following ways:
You can reserve virtual machines according to your project or business requirements. Configuration options include:
You can reserve the appropriate resource allocation for a specified period on one or more virtual machines. Ensure that you:
Note: The Administrator Password field is visible only if you are requesting Windows virtual machines. For the Linux virtual machines request, this field is hidden. Contact your Service Provider for the root password after the virtual machine is provisioned.
Reserve VMware Virtual Machine
Perform the following procedure for requesting uncommon configurations or for reserving a single machine.
  1. Access VMware ESX Management.
  2. Click Reserve VMware Virtual Machine.
    A web form opens with fields for defining the request.
  3. Complete the required form fields.
    Additional form fields populate.
  4. Modify the populated fields as required.
  5. Click Add to Cart and Check Out.
  6. Review your request details, and click Save and Submit Cart.
A confirmation message displays. Your request is processed. An Approving Manager reviews your reservation. You receive an email indicating whether your request was approved or declined. If approved, the email includes information about how to access your resources.
Reserve Using a Template
You can create a virtual machine (or machines) based on a reservation template with predefined resources. A reservation template provides the flexibility to select and deploy virtual machines automatically. You can add additional software packages to the base operating system after it is deployed.
  2. Click Reserve Using a Template.
After successful reservation of virtual machines, you can manage their lifecycles from the self-service portal. You can:
Create and manage snapshots. Snapshots are ideal for capturing complex configurations and rapidly returning machines to a previous state.
Change VMware Virtual Machine
Your virtual machine requirements can change after your machine is available. You can increase or decrease the quantity of CPUs and amount of memory on the virtual machines you reserved. Your Service Provider sets the available configuration options. Additionally, configuration change requests are subject to approval by your service provider or administrator.
  2. Click Change VMware Virtual Machine.
    A web form opens.
A confirmation message displays. Your request is processed. You receive an email indicating whether your request was approved or rejected.
Extend or Return Reservations
As your project and business requirements change, you can modify the durations of your virtual machine reservations.
Note: Your Approving Manager determines the latest date to which you can extend a reservation. You cannot edit the value.
You can return an entire reservation, which lets you restore the unneeded allocated capacity and performance to the resource pool. Before you return a reservation, consider creating a snapshot of your virtual environment in case you require it again later.
You cannot cancel a reservation that is approved and in the Pending Fulfillment status. Wait until the virtual machine is provisioned, and then cancel the reservation.
  2. Click one of the following options:
    A web form opens.
Create, Restore, or Delete a Virtual Machine Snapshot
Snapshots are ideal for rapid, time-saving back-ups and restorations. You typically use snapshots to:
You can create, delete, and restore snapshots from the self-service portal. When working with snapshots, note the following important information:
  2. Click Snapshots.
  3. Click one of the following options:
    A web form opens.
  4. Complete the required form fields.
  5. Modify the optional form fields as required.
  6. Click Add to Cart and Check Out.
  7. Review your request details, and click Save and Submit Cart.
A confirmation message displays. Your request is processed. For new snapshots, you receive an email indicating if your request was approved or rejected along with important information about working with your snapshot too.
Now you know how to reserve and manage VMware ESX virtual machines. You can reserve machines, alter hardware configurations, extend, or return the machines that you reserved, and create and manage snapshots.
