Previous Topic: System RequirementsNext Topic: Software Requirements
Hardware Requirements
This section describes hardware requirements for CA Automation Point.
Client-only Requirements
When used only to run the client programs of CA Automation Point,
Server Requirements
The following sections discuss requirements for installing CA Automation Point on a server machine.
Basic CA Automation Point Processing Load
To run the full server-side programs of CA Automation Point (such as system automation) on a relatively small number of sessions (perhaps with notifications), we recommend you install the product on a Windows-certified server-class workstation with the following minimum attributes:
High-Volume CA Automation Point Processing Load
To use a single server-class machine to perform a combination of CA Automation Point functions (such as system automation, a high volume of notifications, or web server functions), or if the server also has CA NSM installed, we recommend that you install the product on a Windows-certified server-class workstation with the following minimum attributes:
Notification Server Requirements
If you plan to use the notification server component for voice notification, you must install the following hardware and related software:
